Trying to get InfoWindow sample to work
557
03-24-2011 07:10 AM
SaraKidd
Hello all - I hope someone can take a moment to help me out. All I want to do is click on my points and show an InfoWindow. I used this example http://help.arcgis.com/en/webapi/javascript/arcgis/demos/query/query_showinfowindow.html
I replaced the layers with my own and can see my points on top of the background layer. I also altered the fields in the query. When I click on the points, nothing happens. Here is my code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>QueryTask with geometry, queries with multiple results at the same location are displayed in an InfoWindow</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.2/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.2"></script>
    <script type="text/javascript" language="Javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.query");
      var map, queryTask, query;
      var featureSet;
      function init() {
        var startExtent = new esri.geometry.Extent({"xmin":-8625438.488209609,"ymin":4369606.075512551,"xmax":-8441989.620325275,"ymax":4553054.943396885,"spatialReference":{"wkid":102100}});
        //create map
        map = new esri.Map("mapDiv", {extent: startExtent});
        var tiledLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
        map.addLayer(tiledLayer);
         //Add housing portal sites
        var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost/ArcGIS/rest/services/IntranetServices/Portal_SP/MapServer");
         map.addLayer(dynamicLayer);
        //Listen for click event on the map, when the user clicks on the map call executeQueryTask function.
        dojo.connect(map, "onClick", executeQueryTask);
        //Listent for infoWindow onHide event
        dojo.connect(map.infoWindow, "onHide", function() {map.graphics.clear();});
        //build query task
        queryTask = new esri.tasks.QueryTask("http://localhost/ArcGIS/rest/services/IntranetServices/Portal_SP/MapServer/0");
        //Can listen for onComplete event to process results or can use the callback option in the queryTask.execute method.
        //dojo.connect(queryTask, "onComplete", showResults);
        //build query filter
        query = new esri.tasks.Query();
        query.outSpatialReference = {"wkid":102100};
        query.returnGeometry = true;
        query.outFields = ["Organizati", "ProgramTyp"];
      function executeQueryTask(evt) {
        map.infoWindow.hide();
        featureSet = null;
        //onClick event returns the evt point where the user clicked on the map.
        //This is contains the mapPoint (esri.geometry.point) and the screenPoint (pixel xy where the user clicked).
        //set query geometry = to evt.mapPoint Geometry
        query.geometry = evt.mapPoint;
        //Execute task and call showResults on completion
        queryTask.execute(query, function(fset) {
          if (fset.features.length === 1) {
            showFeature(fset.features[0],evt);
          } else if (fset.features.length !== 0) {
            showFeatureSet(fset,evt);
      function showFeature(feature,evt) {
        //set symbol
        //var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.5]));
        //feature.setSymbol(symbol);
        //construct infowindow title and content
        var attr = feature.attributes;
        var title = attr.FIELD_NAME;
        var content = "Organization : " + attr.Organizati
                    + "<br />Program Type : " + attr.ProgramTyp;
        map.graphics.add(feature);
        map.infoWindow.setTitle(title);
        map.infoWindow.setContent(content);
        (evt) ? map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint)) : null;
      function showFeatureSet(fset,evt) {
        //remove all graphics on the maps graphics layer
        var screenPoint = evt.screenPoint;
        featureSet = fset;
        var numFeatures = featureSet.features.length;
        //QueryTask returns a featureSet.  Loop through features in the featureSet and add them to the infowindow.
        var title = "You have selected " + numFeatures + " fields.";
        var content = "Please select desired field from the list below.<br />";
        for (var i=0; i<numFeatures; i++) {
          var graphic = featureSet.features;
          content = content + graphic.attributes.FIELD_NAME + " Field (<A href='#' onclick='showFeature(featureSet.features[" + i + "]);'>show</A>)<br/>";
        map.infoWindow.show(screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    Housing Portal Sample
    <div id="mapDiv" style="width:800px; height:600px; border:1px solid #000;"></div>
  </body>
</html>
I'm obviously new to this but I can't figure out how only swapping out the data layers in the sample results in it not working. Does it have something to do with different geometry types? I commented out the code about the symbol since I have points, not polygons.
Thanks!
JamesGonsoski
New Contributor III
Sara,
I think I had the same problem with that sample and getting it to work with points rather than polygons. I think the trick was that it is easier to successfully query a feature polygon with a screen point rather a feature point with a screen point.
I recall I solved this by creating an extent around my screen point and then using that as the query geometry in the hope that a 'box' would intersect my feature point better than just a screen coordinate and it worked.
Rather than doing this in your code:
Try this:
  var ext = new esri.geometry.Extent(evt.mapPoint.x - 100, evt.mapPoint.y - 100, evt.mapPoint.x + 100, evt.mapPoint.y + 100, globals.spatialRef);
  query.geometry = ext;
Bear in mind that I'm adding map units (which in my case were METERS) to create a 100 sq meter box around the screen point and using that to intersect.
SaraKidd
I made the change but unfortunately the window did not appear when I clicked on the point.
Thank you very much for taking the time to reply.
KellyHutchins
Esri Frequent Contributor
Sara,
If you are trying to display info windows for one layer in your map an easier solution might be to create a feature layer. When you create a new feature layer and add it to the map you can define an info template for that layer. Then when someone clicks on a feature in that layer the info window appears.
Here's  an example showing how this works:
<html>
  <head>
    of the samples on iOS devices-->
    <title>
      Street Trees
    </title>
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      .esriScalebar{padding: 20px 20px; }
      #map{ padding:0; }
    </style>
    <script type="text/javascript">
      var djConfig = {
        parseOnLoad: true
    </script>
    </script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.dijit.Scalebar");
      dojo.require("esri.layers.FeatureLayer");
      var map;
      function init() {
        var initExtent = new esri.geometry.Extent({
          "xmin": -13627755,
          "ymin": 4548254,
          "xmax": -13626718,
          "ymax": 4548849,
          "spatialReference": {
            "wkid": 102100
        map = new esri.Map("map", {
          extent: initExtent
        //Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        var template = new esri.InfoTemplate();
        template.setTitle("<b>${qAddress}</b>");
        template.setContent("${*}");
        //add the street trees to the map
        var featureLayer = new esri.layers.FeatureLayer("http://servicesbeta.esri.com/ArcGIS/rest/services/SanFrancisco/SFStreetTreesRendered/MapServer/0", {
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          infoTemplate:template,
          outFields: ["*"]
        map.addLayer(featureLayer);
        var resizeTimer;
        dojo.connect(map, 'onLoad', function(theMap) {
          var scalebar = new esri.dijit.Scalebar({
            map: map,
            attachTo: "top-right"
          dojo.connect(dijit.byId('map'), 'resize', function() { //resize the map if the div is resized
            clearTimeout(resizeTimer);
            resizeTimer = setTimeout(function() {
              map.resize();
              map.reposition();
            }, 500);
    </script>
  </head>
    <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false"
    style="width: 100%; height: 100%; margin: 0;">
      <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
      </div>
    </div>
  </body>
</html>
SaraKidd
Works great! Thank you!
