URGENT: API 3.0 failing from arcgis online
694
10-17-2012 10:29 AM
SteveDale
Our app is now failing with a reference to:
<script type="text/javascript"
src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script>
Here is the link to our app:
http://map.toronto.ca/maps/map.jsp?app=TOInView
It appears that something has changed in the build for the api online?
Steve
derekswingley1
http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0 loads without issue. Please elaborate on what you changed or what you're trying to do.
BillDaigle
Occasional Contributor III
Are you attempting to upgrade from version 2.x?  If so, you should read "Migrating to 3.0" documention at http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm.
PaulBushore
Just took a quick look and make a call to <scripttype="text/javascript" src="js/date.js?1"></script>
I couldn't find a js/date.js?1 but I did find a http://map.toronto.ca/maps/js/date.js file. Could that path be wrong? Seems all your other calls reference the /maps directory.
Edit:
Looked at the paths for js/GC* files and all of them allow me to access the files when I nest them in the /maps directory.
Hope it helps, kind of a novice with all this.
