I'm trying to use
view.watch ("finished", function(){
console.log ("animation finished")
once I get something like this working. I have created an array of cameras to create a series of animateTo animations s to so a multiple part fly through using a loop.
Currently I can't get them to play in sequence as I loop through the camera array
Thanks for any help
Probably because they are asynchronous calls. You may call them in order of 1, 2, 3, but 2 could return before 1.
Hi Rex,
you can totally do this. I set up a example here: Chaining animations
var cameras = [ { "position": { "x": 860866.9791700585, "y": 5776206.000594208, "spatialReference": { "wkid": 102100, "latestWkid": 3857 }, "z": 5182.999999999069 }, "heading": 270.0000000089171, "tilt": 79.9999999867539 }, { "position": { "x": 852082.9255940468, "y": 5784990.056948395, "spatialReference": { "wkid": 102100, "latestWkid": 3857 }, "z": 5182.999999997206 }, "heading": 180, "tilt": 79.9999999681663 }, { "position": { "x": 843580.3118266261, "y": 5776487.440662808, "spatialReference": { "wkid": 102100, "latestWkid": 3857 }, "z": 5182.999999997206 }, "heading": 90.00000000865207, "tilt": 79.99999998165575 }, { "position": { "x": 852039.3825317192, "y": 5767378.401137406, "spatialReference": { "wkid": 102100 }, "z": 5182.999999999069 }, "heading": 359.99999914622634, "tilt": 79.99999998987897 } ].map(Camera.fromJSON); var delay = function(delay) { var deferred = new Deferred(); setTimeout(function() { deferred.resolve(); }); return deferred.promise; }; window.animateCamera = function() { var timeline = cameras.concat(); var next = function() { var camera = timeline.shift(); if (camera) { return view.animateTo(camera).then(next); } } var animation = promiseUtils.resolve() .then(function() { return delay(500); }) .then(next); animation.then(function() { console.log("animation finished done"); }); }; var logProperty = function(newValue, oldValue, prop) { var oldValueString = (oldValue && typeof oldValue === "object") ? "[object]" : oldValue; var newValueString = (newValue && typeof newValue === "object") ? "[object]" : newValue; console.log(prop + " changed from " + oldValueString + " to " + newValueString); }; view.watch("stationary, animation, interacting", logProperty)
Have fun!
