EBS version 1.10.
The setting.tsx file imports IMConfig type from:
import { IMConfig } from "../config";
Which has:
import {ImmutableObject} from 'jimu-core';
interface Field {
label: string,
maxLength: number,
includeTime: boolean,
interface EditorLayerConfig {
title: string,
fieldConfig?: Field[],
addEnabled: boolean,
updateEnabled: boolean,
deleteEnabled: boolean,
export interface Config{
enableAdvancedEditing: boolean;
editableLayers:EditorLayerConfig[],
allowedOperations:string[]
export type IMConfig = ImmutableObject<Config>;
The config.json file is under the widget folder, which has:
"enableAdvancedEditing":true,
"allowedOperations":["create","update"],
"editableLayers":[{
"title":"Rail Features",
"addEnabled": false ,
"updateEnabled": true ,
"deleteEnabled": false ,
"fieldConfig":[
{"name":"NEW_CLASS","label":"New Class", "maxLength":50},
{"name":"CHANGED_CLASS","label":"Changed Class", "maxLength":1},
{"name":"CHNG_DATE","label":"Change Date", "maxLength":8, "includeTime":false},
{"name":"CHNG_RACF","label":"Change RACF", "maxLength":10},
{"name":"LAT","label":"Latitude"},
{"name":"LNG","label":"Longitude"},
{"name":"COMMENTS","label":"Comments", "maxLength":255}
The rest of setting.tsx file has:
export default function Setting(props: AllWidgetSettingProps<IMConfig>){
return (
<div className="widget-setting-js-api-widget">
<SettingSection
title={props.intl.formatMessage({
defaultMessage: defaultMessages.labelSectionLayers,
<TextInput
className="w-100"
name="text"
id="txtEditableLayers"
value={
props.config.editableLayers
? JSON.stringify(props.config.editableLayers)
placeholder={defaultMessages.placeholderEditableLayers}
onBlur={(evt) => {
onPropertyChange("editableLayers", JSON.parse(evt.target.value));
</SettingSection>
</div>
But props.config does not contain entries for:
editableLayers
allowedOperations
Setting.tsx code is copied from working version in ebs 1.05.
And there the prop.config values are populated:
(see image1)
When running the widget, the settings section shows empty for those missing configurations:
(see image2)
* [‘create’, ‘update’] above is just placeholder hint text, the textbox is actually empty… but it should be populated with text => ‘["create","update"]’.
Also Editable Layers should be populated from values in config.json.
- Does 1.10 support React functions for setting.tsx file?
- Provide a working example where IMConfig/config.ts/config.json values (above) are properly imported..?
Thanks.
