version 4.23.7 bug SceneView is used on the mobile terminal. After loading, the scene moves, and an error occurs, causing 3d cannot be used normally
485
05-06-2022 01:49 AM
CPC
Uncaught TypeError: Cannot read property '0' of null
webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/chunks/vec3.js:53:2501 TypeError: Cannot read property '0' of null
at I (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/chunks/vec3.js:53:2501)
at Y (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/3d/state/utils/navigationUtils.js:59:1727)
at It (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/3d/state/utils/navigationUtils.js:59:12330)
at l._panningSpherical (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/3d/state/controllers/global/PinchAndPanController.js:38:10451)
at l.update (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/3d/state/controllers/global/PinchAndPanController.js:38:6923)
at l.end (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/3d/state/controllers/global/PinchAndPanController.js:38:7095)
at i._endController (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/3d/input/handlers/PinchAndPanNavigation.js:11:1013)
at i._handleDrag (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/3d/input/handlers/PinchAndPanNavigation.js:11:781)
at s.eval [as _callback] (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/3d/input/handlers/PinchAndPanNavigation.js:11:232)
at i._handleEvent (webpack-internal:///./node_modules/_@arcgis_core@4.23.7@@arcgis/core/views/input/InputHandler.js:9:2680)
Tags (1)
