Visible Shifts in features while loading in GOOGLE maps
727
11-03-2016 10:39 PM
PrasannaSivakumar
I was using a layer which is in wkid:4326 projection and adding to the map. It is fine when I had arcGIS's satellite imagery as basemap, but when I use Google's satellite imagery base map, on around 12-13 LOD level, the features are starting to shift from its position and not overlapping with the base map. If I pan the map the layers are moving separtely from the base map like they are 2 different layers.
Please see the uploaded images for the illustration.
If any one else had this problem and found any solutions please share it in here, any help will be appreciated.
Thank you!
