Hello All,
I'm using vite.js (2.6.4) w/ the v4.21.2 of JSAPI and getting the warning listed below when I start up the dev server. I heard Rene mention something about this in one of his videos and understood it to be a problem fixed in 4.19. However I can't find mention of it in the changelog. I'm also confused because it looks like a Webpack problem when I thought vite.js used Rollup. Can anyone please clarify for me?
Thanks!
--john
/Users/jcc/projects/webmap-demo/node_modules/.vite/chunk-3UH5BQI4.js
1823| return module2[exportName];
1824| }
1825| return import(
1826| /* webpackInclude: /\.entry\.js$/ */
1827| /* webpackExclude: /\.system\.entry\.js$/ */
The above dynamic import cannot be analyzed by vite.
See https://github.com/rollup/plugins/tree/master/packages/dynamic-import-vars#limitations for supported dynamic import formats. If this is intended to be left as-is, you can use the /* @vite-ignore */ comment inside the import() call to suppress this warning.
Plugin: vite:import-analysis
File: /Users/jcc/projects/webmap-demo/node_modules/.vite/chunk-3UH5BQI4.js?v=0d4ab57f
