WAB DE: Is there a way to allow widgets to only work with visible layer from layerlist?
311
05-31-2019 04:39 AM
MarquesMunson1
I have a dataset that contains information for countries spanning over a number of years. I currently have each year listed as a different layer in my web app (Country A with 2019 data, Country A with 2018 data, etc). Is it possible that when I toggle layers on/off using the layerlist widget, that other widgets will update accordingly? For example, a pie chart (infographic) will update the results based on the visible layers chosen by the user.
