Web GIS Application map issue
1591
07-08-2014 03:45 AM
Meka_KiranKumar
We are Customizing a Web GIS Application in HTML5 using ArcGIS Java script API, when we are trying to navigate in map area using zoom in or zoom out button, the pointer is not picking the location where we are clicking it is geting clicked in another location. Can some body help in resolving this issue? if we resize the browser and click the zoom button then it's working fine.
TimWitt
It would be helpful if you could post your code or a link to the application.
JeffPace
you need to tag this post with javascript and/or web developers or no one will find it.
KenBuja
MVP Esteemed Contributor
Are you resizing or repositioning your map before the user clicks on the map to zoom? If so, take a look at this thread or this thread.
DonOpgenorth
I've
moved your post into the
Arcgis API for Javascript    space. You will get a much
better answer here as the
GeoNet Help is intended for community
help and feedback. I have also added in a few additional tags. You can see more
on the community structure, and what topics are under each space from the
following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
JeffPace
Have you included the required/appropriate css files?
