Web Scene service
1114
10-08-2017 12:38 AM
JayakumarKamalakkannan
I have created webscene service and URL is  Scene Viewer . I need to use this webscene service in my customized application. Could you please let me know how to achieve this. My code snippet, but it is not working
var scene = new WebScene({
portalItem: { // autocasts as new PortalItem()
var view = new SceneView({
map: scene,
container: "viewDiv",
padding: {
top: 40
RobertScheitlin__GISP
The portal item id is not a sceneview it is just for a map layer so you need this code:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Create a layer from a portal item - 4.5</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.5/esri/css/main.css">
  <script src="https://js.arcgis.com/4.5/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/SceneView",
      "esri/layers/Layer",
      "dojo/domReady!"
    ], function(
      Map, SceneView, Layer
      var map = new Map({
        basemap: "gray"
        map: map,
        zoom: 16,
        center: [55.17, 25.0295]
       * Create a layer from an existing Portal item hosted
       * in ArcGIS Online using the ID of the item.
      Layer.fromPortalItem({
        }).then(addLayer)
        .otherwise(rejection);
      // Adds the layer to the map once it loads
      function addLayer(lyr) {
        map.add(lyr);
      function rejection(err) {
        console.log("Layer failed to load: ", err);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/domReady!"
    ], function(
      var map = new Map({
        basemap: "gray"
        map: map,
        zoom: 16,
        }).then(addLayer)
        map.add(lyr);
  </script>
</head>
<body>
</body>
</html>
Hi
Thanks for the solution and it is working.
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
Done
