I'm still learning javascript and have gone through some tutorials and read a lot. I've been able to get a simple map and a simple geocoder but cannot seem to get them to work together. I'm not sure what order they go or if they should all be in one. I used a Geocoder Service from ArcGIS Server and a simple parcel layer from a MapServer service. Any help would be much appreciated.
Good morning John, well some progress is being made. The topo map shows up with the city limit line, which is layer "0". The parcel layer is "1". Do I need to identify the parcel layer in some way so it will show up too? Thanks
passing specific layerIds to imageParameters is a technique to restrict the layers from the original service that are drawn in your appl;ication. you can either skip supplying the imageParameters in your ArcGISDynamicMapService layer constructor if you'd like all the layers in the service to display, or add all the individual layerIds you want to the array and continue to include it in the constructor.
//imageParameters.layerIds = [0,1,2];
layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer");
Yeah, it worked and looks great. I had to tweak the lat/long to get it to center a bit better for our city. There are a few more things I need to add to this and would like your help if possible. Can I do that or should I call in to support?
