bathymetric map
3346
05-10-2013 09:42 AM
Maria_IzabelManes
Hello!
I'm in a project where I'm supposed to make a bathymetric map of a flooded crater. I'm testing how to do it and I had a few problems.
A remote controlled boat collects the data by a GPS (location and depth). At my office, I take the SDCard from the boat and the file is a text format. The information on the file is like this:
$GPRMC,174859.000,A,4505.1729,N,06420.5123,W,1.75,28.53,080513,,,A*46
$SDDBT,6.6,f,2.0,M,1.1,F*04
I tried to use 2 programs to import the data - Undersee Explorer and ArcMap but none of them were able to recognize this format (.txt). I also tried GPSBabel to convert but it didn't work.
I need a file in sonar log (.slg or .sl2). I'm pretty sure that is not a hard issue, but I can't figure it out - I've never done this before.
Any suggestion will be welcome!
Thank you!!
EricWienckowski
Hi Maria,
Did you figure it out? I could certainly help if you didn't. Your best bet is to export a SLG or SL2 file.
