Here is a copy/paste set of details regarding the raster file:
<Columns_and_Rows> 30001, 28766
<Number_of_Bands> 3
<Cell_Size__X._Y_> 0.013888889, 0.013888889
<Uncompressed_Size> 2.41 GB
<Format>TIFF
<Source_Type>Generic
<Pixel_Type>unsigned integer
<Pixel_Depth>8 Bit
<Colormap>absent
<Pyramids>level: 7, resampling: Nearest Neighbor
<Compression>LZW
<Mensuration_Capabilities>Basic
<Status>Permanent
<Extent><Top> 399.527777778 <Left> 0 <Right> 416.680555556 <Bottom> 0 <Spatial_Reference>WGS_1984_Web_Mercator_Auxiliary_Sphere
<Linear_Unit>Meter (1.000000)
<Angular_Unit>Degree (0.0174532925199433)
<False_Easting>0 <False_Northing> 0 <Central_Meridian> 0 <Standard_Parallel_1> 0 <Auxiliary_Sphere_Type> 0 <Datum>D_WGS_1984
<Statistics><Band_1><Build_Parameters>skipped columns:1, rows:1, ignored value(s): <Min>0 <Max>255 <Mean>253.5990525616515 <Std_dev.>14.24670552247798 <Classes>0
<Band_2><Build_Parameters>skipped columns:1, rows:1, ignored value(s): </Build_Parameters><Min>6<Max>255<Mean>253.6721133398082<Std_dev.>9.882874895876389<Classes>0
<Band_3><Build_Parameters>skipped columns:1, rows:1, ignored value(s): </Build_Parameters><Min>6<Max>255<Mean>250.7431879087078<Std_dev.>24.38898611239873<Classes>0
Thank you for any input you might have.
