Flow Direction Arrows Changing In Export
1430
5
08-28-2018 01:04 PM
JacobConshick
I am trying to create flow direction arrow for my raster. It is important we have this for storm water control.
What I did to start was create a surface raster for my area. From that I created a flow direction raster which was then reclassified to show direction in terms of N,S,E,W. Finally I went into the symbology tab.
It was in the symbology tab that I changed the rasters properties to a Vector Field and generated the size and quantity of arrows that is required for the permits.
When I tried to export the map though the arrow become extremely tiny and hundreds filled the map making it look like a grid.
Does anyone know how to prevent this from happening without having to take a screen shot?
DanPatterson_Retired
from Pro
Change the symbology of imagery—ArcGIS Pro | ArcGIS Desktop
in the vector field section, what options did you experiment with?
There are other threads on geonet about "vector field" if you want to search those
JacobConshick
Hi Dan,
I will take a look on the forum for vector field. I wasn't sure where to start.
I did look at the link you provided. from what I can tell there maybe a way to make the vectors static unchanging. It just doesn't explain how to do that though.
export the map vs export the raster hmmm
might be worth looking at this
Export or convert raster datasets—ArcGIS Pro | ArcGIS Desktop
since there is a suggestion that one form might keep the symbology better than the other
JacobConshick
I did try that but the issue still remains.
Currently I have 40 flow arrows that show me the direction of the contours
These are the Stats
Each symbol represents a tile size: 12 Screen Pixel
Vector Average
Min Symbol Size 20%
Max Symbol Size 40%
What happening is when I go into layout I will see all 40 but when the Map is generate as PDF, TIFF, JPEG. or other it rescales the directional arrows, down sizing them and adding more to fit the area.
I just want to keep my 40 arrows and no matter what I have tried does that.
Jacob, I don't see anything to fix that offhand.  Screen grab for now and perhaps ship some sample data illustrating the issue you are having  There are too many things between the screen the file that could be the cause, the least of which may be the output format.
It could even be something like scaling
Map scales and scale properties—ArcGIS Pro | ArcGIS Desktop
as in going to a higher resolution output file from the screen.
