How to create variables for coastal cities?
576
05-01-2017 09:00 AM
JoãoFrancisco_Pugliese
I have a shapefile for a coastline, I have the boundaries and centroid points for municipalities. I created a measure of "Distance to coastline" but I also would like to know if a city area is in contact with the coast or not.
I attempted to find it online but did not come up with anything.
Any ideas?
João
forestknutsen1
MVP Regular Contributor
You could run an intersect with points as the output... If you get a point at least part of the city is on the coast.
How Intersect works—Help | ArcGIS Desktop
Intersect—Help | ArcGIS Desktop
XanderBakker
Esri Esteemed Contributor
If your coast lines are indeed lines, you could use a select by location and apply a tolerance (search distance):
If your coast "lines" are polygons representing land you could evaluate if the coast polygon borders touch the cities but you wont be able to apply a search distance:
If your coast lines are polygons representing the sea, you could use the intersect and apply a search distance to account for lack of precision between the layers.
