Lambert conformal conic p
1064
5
08-18-2017 03:14 AM
AdamVaughan
Dear Community,
I'm trying to import and make rasters from netcdf data. It is 1 km resolved data and has a Lambert Conformal Conic projection system. I've tried making a custom projection for it but cannot seem to get the parameters right. Any ideas what parameters I would need to use for the following. The domain is centred on 39.31N, 116.65E.
char Lambert;
:grid_mapping_name = "lambert_conformal_conic";
:latitude_of_projection_origin = 39.51774597167969;
:longitude_of_central_meridian = 110.0;
:standard_parallel = 20.0, 50.0;
:earth_radius = 6370000.0;
Cheers,
DanPatterson_Retired
longitude is negative in the western hemisphere ie -110, and you are sure yours is 110E?
Are you modifying a lambert from the country where the dataset resides?
AdamVaughan
Hi Dan,
 Yes 110E is correct as the data is situated over China.
Cheers,
And you have ruled out it just being a LCC that is routinely used within China?
MKennedy-esristaff‌ would have more insight on whether this may be the case or how to safely modify a LCC
I just wanted to make sure that East was indeed East
AdamVaughan
Hi Dan,
I'm pretty sure its a custom LCC. The most similar LCC projection (Asia_North_Lambert_Conformal_Conic) which I was able to find in Arc has standard parallels different by a few degrees.
I've tried viewing the data quickly using NASA's Panoply 4 view and it looks OK when projected.
Cheers,
MelitaKennedy
Esri Notable Contributor
The hard part is probably making the custom GCS. Here's the complete well-known text:
PROJCS["China_NetCDF",GEOGCS["GCS_Sphere_6370000",DATUM["Sphere_6370000",SPHEROID["Sphere_6370000",6370000.0,0.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",110.0],PARAMETER["Standard_Parallel_1",20.0],PARAMETER["Standard_Parallel_2",50.0],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",39.51774597167969],UNIT["Meter",1.0]]
Copy the string to a text file (Notepad, not Wordpad or Word) and give it a .prj extension. Then you should be able to Import it when setting the data frame or defining the coordinate system of a dataset.
Melita
