ArcGIS Maps for Adobe CC Questions
91
1.1M
196
Open | I am posting this to express interest in a documents board for the ArcGIS Maps for CC community. There is little docu... by JamesPoeschel New Contributor III 1 2 | 1 | 2 | |
Open | Hello Anna, Yes, this was more of a UI question/request. I feel it would be beneficial to be able to read the error m... by LRSmith New Contributor III 0 0 | 0 | 0 | |
Under Consideration | Is it possible to work with 3D layers in ArcGIS Maps for Adobe CC? When I export a 3D map to aix, the layout comes in... by GraceTortorici_ New Contributor III 1 2 | 1 | 2 | |
Open | I really like the ability of Pro to Export to AIX as it preserves the layer settings and is a lot easier to work with... by mcparkstrails New Contributor II 3 0 | 3 | 0 | |
Open | Currently it seems that rasters export without an alpha channel -- they maintain a similar look, but their opacity is... by wayfaringrob Frequent Contributor 2 1 | 2 | 1 | |
Under Consideration | I use halos on nearly every map I make. When exporting a map with haloed text, though, they always look something lik... by wayfaringrob Frequent Contributor 2 15 | 2 | 15 | |
Open | It would be ideal to have grids and graticules built-in rather than having to get them from another source. Could the... by AletheaSteingisser New Contributor II 0 0 | 0 | 0 | |
Open | We would like to create scale bars that are adjustable in measurement, and also have graphic styles to choose from. T... by AletheaSteingisser New Contributor II 3 0 | 3 | 0 | |
Open | When I export an Illustrator file (.AIX) from ArcGIS Pro on a Windows machine, I would like to open that file in Illu... by FrancisHourigan1 Occasional Contributor 3 3 | 3 | 3 | |
Open | Hi! Is it possible using Illustrator and the complimentary version of arcgis to draw a regional map and then add a gr... by melodycook New Contributor II 1 0 | 1 | 0 | |
Open | Instead of creating a separate element for text outline, use the appearance panel to create a bottom stroke layer tha... by Anonymous User Not applicable 0 0 | 0 | 0 | |
Implemented | Currently, one has to manually select features and re-apply each blend mode once in Illustrator to achieve the same e... by wayfaringrob Frequent Contributor 0 7 | 0 | 7 | |
Under Consideration | This has probably been mentioned, but adding the ability to export to geospatial formats would be great. GeoTIFF or g... by PaulFyfield New Contributor II 1 4 | 1 | 4 | |
Needs Clarification | Is there a way that objects within an I-Frame (embedded webmaps/apps on a web page) can pass along information to obj... by MarcHummel New Contributor II 1 2 | 1 | 2 | |
Open | First of all, I want to thank Madhura Phaterpekar for helping me solve my KML sync issues!I have been successfully bu... by MikelSavage New Contributor III 2 1 | 2 | 1 |
Idea Submission Guidelines
