Road Layer
431
11-25-2021 07:22 PM
CassieMaynard
Hey Guys,
I have had some issues with the vector basemap not grouping the roads layer when using it in the Maps for Adobe plugin. I know that you can group by weight after its brought in to illustrator but when we are doing things like roundabouts that becomes an issue. Is there a work around where i can group all of the road types in the compilations pane or in ArcGIS online before bringing it into Illustrator?
Any suggestions will help
JamesPoeschel
What basemap are you using? I can see roundabouts in illustrator after bringing it in as an AIX file:
If this doesn't work for you, I guess you could create different road layers by road type using your own roads layer in Pro.
