Esri SDK map is not rendering in Hololens2
236
09-26-2023 12:20 AM
albertoxrf
Hello!
In Unity Editor the map renders quite well but when I compile it (and a test cube that I create with the same material than the map) it doesn't render in the HoloLens device. I am using URP too. I've already updated the render pipeline and the shaders but with no positive result.
The object is present because I see the colliders but it doesn't render.
