ArcGIS Maps SDKs Native Blog
Other Boards in This Place
Latest Activity
(186 Posts)
Rachael_Ellen
New ArcGIS Blog Post! This blog demonstrates how to integrate RESTful services, such as the places service, with the Native Maps SDKs by making HTTPS requests using native development frameworks.
Read more...
more
2 0 317
MarkBaird
With the recent long-term support (LTS) release of Java 21, JavaFX 21 and support for the new JDK coming in the 8.4 release of Gradle, the Java Maps SDK team have been busy testing our 200.2 release to make sure everything is working correctly with this latest LTS version of Java.
With testing successfully completed, we are pleased to announce the 200.2 release of the Java Maps SDK supports Java 21.  Our system requirements page has been updated and our Gradle starter project has also been modified to ensure it is compatible with Java 21.
The upgrade path for developers wanting to switch to Java 21 is very simple and only the following versions will need updating in your Gradle build scripts:
  • Gradle 8.4
  • JavaFX Gradle Plugin 0.1.0
So, if you want to use Java 21 in your Maps SDK apps, it’s a great time to upgrade to our 200.2 release.
more
3 3 488
Rachael_Ellen
New ArcGIS Blog Post! Learn how to create a custom dynamic entity data source to wrap a data feed for use in your ArcGIS Maps SDKs for Native Apps applications.
Read more...
more
0 0 369
Rachael_Ellen
New ArcGIS Blog! This blog is the second in a series of articles which demonstrates how the beta release  of the ArcGIS Maps SDK for Java  (with ARM Linux support) can be used for IoT data recording apps.
Read more...
more
0 0 386
MichaelBranscomb
Esri Frequent Contributor
ArcGIS Maps SDK for Local Server 200.1 is an incremental compatibility release that provides support for geoprocessing and map packages created with ArcGIS Pro 3.x. You can use version 200.2 of the ArcGIS Maps SDKs for .NET, Java, and Qt with this release of Local Server.
Read more...
more
0 0 446
Rachael_Ellen
New ArcGIS Blog! The August 200.2 update of the Native Maps SDKs brings some exciting new capabilities for 3D visualization and application development.
Read more...
more
0 0 294
Rachael_Ellen
The ArcGIS Maps SDKs team is pleased to bring you the next update to the 200.x series of Native Maps SDKs: 200.2, and it’s full of exciting new features and important updates to existing ones.
Read more...
more
1 0 262
Rachael_Ellen
In this latest announcement blog about offline tracing capabilities for geodatabase-based utility networks in the ArcGIS Maps SDKs for Native Apps, learn about aggregated geometry, isolation traces and tracing in hierarchical networks.
Read more...
more
1 0 256
Rachael_Ellen
Our latest developer blog will help you discover the advantages of using JavaFX properties and listeners with the ArcGIS Maps SDK for Java to make great UI experiences, and increasing developer productivity.
Read more...
more
1 0 264
Rachael_Ellen
In our latest ArcGIS Blog on utility networks, learn how the 200.1 release of the Native Maps SDKs and ArcGIS Enterprise 11.1 enables your application to download a utility network and trace offline.
Read more...
more
1 0 224
93 Subscribers
