Inquiry on Creating Symbols for Extended Objects in S-57 Electronic Navigational Charts
441
11-21-2023 10:32 PM
songqin
New Contributor III
I am reaching out to seek guidance on the process of creating symbols for extended objects in S-57 Electronic Navigational Charts (ENC) and ensuring their correct display in ArcGIS Pro and ArcGIS Maritime Server.
I have extended some objects in the S-57 format by adding subclasses, subclass values (fields), and modifying related files such as nautical.gdb, s57datadictionary, NIS_product.xml, and ENC_product.xml. I have successfully exported the modified data into a *.000  file.
However, I am now facing challenges in understanding how to create symbols for these extended objects and ensure their proper display in both ArcGIS Pro and ArcGIS Maritime Server. Specifically:
  1. In ArcGIS Pro:
    • When loading the 000 file in ArcGIS Pro, how can I ensure that the symbols for the extended objects are correctly displayed? Are there specific tools or steps I should follow to achieve this?
  2. In ArcGIS Maritime Server:
    • How can I ensure that the extended object symbols are correctly displayed in ArcGIS Maritime Server? Are there specific configurations or tools that need to be applied to achieve this?
I would appreciate it if you could provide a detailed workflow, step-by-step instructions, and information on the tools involved in achieving the aforementioned goals.
Thanks~
TomDePuyt
Hello,
Great to hear that you have successfully extended the ArcGIS Maritime desktop solution to include your extra objects and attributes.
If by viewing in ArcGIS Pro, you mean the ENC Layer, there is no current capability to extend the portrayal.  However, you can extend the the S57DataDictionary.xml and S52 lookup tables.  By default, they are located at C:\Program Files\ArcGIS\Pro\Resources\ENC    You can add your new objects and attributes to the S57DataDictionary.xml.  This will allow them to be recognized when using the Explore tool.    You can update the lookup tables to include your new objects and potential attribute combinations as well.  By default the new objects will display as magenta "?" symbols if not found in those tables.  Since you are unable to add new symbols, you will have to use an existing symbol in the lookup table to display the feature.   If you require more detailed steps on how to do this, then please email the maritime team at maritime@esri.com and I can assist.
As for ArcGIS Maritime Server, you can extend and add new S-52 symbols.   Similar to the ENC Layer in Pro, you have the S57DataDictionary.xml and S52 lookup tables.   By default, they are located at C:\arcgisserver\directories\maritimeserver\maritimechartservice\controlfiles
As for S-52 symbols, you will need to create them yourself, we do not have an S-52 symbol editor, nor do I know where one exists.   I do know other people have created symbols and plugged them into our solution.  Some just took an existing symbol and modified the values.  My recommendation is to do that and review the S-52 documentation on symbology for guidance.  S-52 PresLib Ed 4.0.3 Part I_Clean.pdf and S-52 PresLib Ed 4.0.3 Part I Addendum_Clean.pdf.  Refer to https://iho.int/en/standards-and-specifications if you don't have those documents.
Once you create the new symbols you just put them in the symshow folder, default location is C:\arcgisserver\directories\maritimeserver\maritimechartservice\controlfiles\S52PresentationLibrary\symshow and link them to your new entries in the S-52 lookup tables you modified.  C:\arcgisserver\directories\maritimeserver\maritimechartservice\controlfiles\S52PresentationLibrary\lookup
If you are adding new S-57 Objects, those objects when entered into the S-52 lookup tables will need to be assigned a view group.  If you create new view groups, then you will need to make sure those values are also added to the S52DisplayProperties.xml file at the bottom in the ViewingGroups sections.   Then verify they are in an existing range under the ParameterGroup name = ViewOverGroups.  This defines the layers that are created when you start the Maritime Chart Service's map service.  If they are not part of one of the layers, then those features cannot be turned off in the display.  This is all part of S-52 and defined in the documents I mentioned.
In order to see the new symbols, you must delete and rebuild your senc files.
Thanks
songqin
New Contributor III
Is the email  address “maritime@esri.com” correct? All the emails I sent failed
TomDePuyt
Yes, maritime@esri.com is correct.   I sent you my email in a direct message if you still need to contact me.
