Inserting IHO/INT1 Compass Rose
678
10-20-2021 05:46 PM
JustinOdell
Occasional Contributor III
Hi all,
I wish to insert an 'IHO / INT1' standard compass rose into an ArcGIS Pro layout.
I have the 'Maritime' licensing extension turned on. When I go to insert > north arrow and do a search for "rose" or "compass", I do not see any IHO or INT1 looking compass rose options.
What is the best way to configure an official hydrographic chart compass rose in ArcGIS Pro?
Tags (4)
ABishop
MVP Regular Contributor
@JustinOdell
I have published a "How To" document to accomplish this very thing!  I shared it with you in the attachment.
Amanda Bishop, GISP
CraigTGreene
Hi Justin,
Since you have the maritime extension, you should be able to use the attached stylx with a maritime geodatabase. You need to insert a feature into TidesAndVarirationsP, under the MAGVAR subtype.
You can calculate magnetic variation and annual change using the Calculate Magnetic Components tool https://pro.arcgis.com/en/pro-app/latest/tool-reference/topographic-production/calculate-magnetic-co...
Use the option to Connect Symbol Properties to Attributes to apply the geographic rotation (not graphic) of the arrow. https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/attribute-driven-symbology.ht...
Let me know if you have more questions.
