It would be useful to include a duration parameter to the standard alerts available in ArcGIS Monitor. For example, I can currently set up an alert to fire when my CPU goes over 90% utilization. It would be more useful if that alert only fired when the CPU is over 90% for five minutes.
Oh man, this would be so great!!! As it stands, I've disabled all the cpu load alerts because they do frequently spike at 95+%. If I could configure Monitor to only alert me when they spike for x minutes... that would be a godsend.
Hi @SteveCacioppo and @RoyceSimpson,
> It would be useful to include a duration parameter to the standard alerts available in ArcGIS Monitor. ... It would be more useful if that alert only fired when the CPU is over 90% for five minutes.
This capability will be available in the forthcoming ArcGIS Monitor 2022 release. If you set your data collection interval to 1 min, then when you configure an alert and set the back interval to 5 (this means each interval will equal 1 min), this should meet your needs.
FYI, ArcGIS Monitor 2022 is targeted for release in Q4 2022.
Hope this helps,
