It would be great to be able to check the validity of an SSL certificate on an endpoint and to alert when that certificate is expiring within a certain amount of days. This was implemented as a common extension for previous versions of ArcGIS Monitor. Alternately, this could be an add-on to an HTTP collector, if that was made available with a new ArcGIS Monitor release.
Hi @tschultz - Thanks for this suggestion! The dev team will be considering how to implement this as part of a future release. As you said, either as a core feature or through supporting extensions
