Hello
I've been installing many architectures in HA lately and every time I have to move the WebGISdr to a single server to back up safely.
It would be nice to have it integrated into ArcGIS Monitor with the following features
1. Configuration directly from ArcGIS Monitor
2. Scheduling Task
3. Retention date
4. Log and Alert fail or succes
5. real-time backup status
6. Allert space destination Backup
a little note, ArcGIS Server when backing up saves its temp in the local user of the server, many users I use don't have the Logon rights is it possible to specify the TEMP in the Directories?
obviously also the possibility to always launch the restore from ArcGIS Monitor, the dream would be to be able to restore each single component separately
Thank you
I propose integrating monitoring for the WebGISDR tool within the ArcGIS Monitor product. This tool is responsible for backing up ArcGIS Enterprise. The objective is to establish monitoring capabilities for this tool to notify administrators/managers regarding the success or failure of backup operations. This ensures timely awareness and swift action in response to any backup-related issues.
It would be nice if this integration of the webgisdr tool into Monitor also backed up Monitor and the Monitor Database. I am currently trying to back up monitor, and the database and I'm struggling a bit, cause I am not familiar with prostgres. so it would be nice if a tool was available to just do it.
That would be very helpful.
