ArcMap 10.1 fails to start
1109
09-11-2012 06:04 AM
SteveLasiter
I've spent some time searching here, as well on search engines and think I have exhausted the normal issues.
I have 10.1 Desktop (Editor) installed on a Windows 2008R2 server with recent patches. I also have a clone of this server in VM format (Hyper-V) on test. The differences are total memory (32GB vs 16GB),  total cores "hyperthreaded" (24 vs 4), and drivers for real hardware vs virtual hardware.
Before removing ArcMap 9.3.1 and installing 10.1, I tried the same on the VM without issue. I installed 10.1 on the real server without issue, but it will not start ArcMap or ArcCatalog. I do not have the Data Interop extension loaded (possible OpenGL 2.0) issue, but it still fails when loading extensions according to the log.
Installed extensions (defaults - not authorized) are:
Network Analyst
3D Analyst
Spatial Analyst
Geostatistical Analyst
Publisher
Tracking Analyst
Schematics
VBA
Any thoughts while I wait for ESRI to validate my customer number so I can get support?
Bryan
EricBowman
Occasional Contributor II
Hi Bryan,
Have you tried repairing the installation?  Not sure it's an extension issue. Also, are you an administrator of the VM?
Regards,
Eric
SteveLasiter
I tried the installation twice. Although I had installed a full default on the VM, I really didn't need all that on production so I did a minimal installation. That did not start, so I un-installed it all and then did a full install. Still did not start.
I have local admin on both the VM and production iron. Both remote desktops sessions are set up the same (I thought it might be a color issue with that).
My guess is that some extension panics over the number of cores. I sent the dump file to support, but have yet to hear back from them.
Bryan
