Export Route with Street names
1214
06-15-2014 08:48 AM
DavidLamb
I've used network analyst's closest facility tool to calculate the routes from a single incident to 21 facilities. Ending up with 21 routes. I would like to know the name of the streets that the route takes. This information is available from the Directions dialog. Is it possible to export a route as segments with the street names as a attribute? Does anyone know of a good method to get this information?
Thank you,
David
MelindaMorang
The best way to do this is to use the Copy Traversed Source Features tool.  It will create a feature class of the network edges that were used to create your closest facility routes, and you can export the names from that.
