Hi Everyone,
I have an ArcGIS Python Toolbox that loops through a Location-Allocation problem, to analyze changes in allocation based on our growth forecasts. When I run it, the first iteration of the loop takes 10 minutes, but every subsequent loop takes much longer than the previous. By the 10th iteration, it takes multiple hours. Any idea on what is going wrong?
Code:
import arcpy
import os
import pandas as pd
import numpy as np
import arcgis
from arcgis.features import GeoAccessor, GeoSeriesAccessor
def location_allocation_tool(nd_layer, travel_mode, geodatabase, demand, scc_layer, line_barriers, search_cutoff, site_count=20):
if 'yr0' in demand:
year_tag = 'Capacity_Current'
else:
year_tag = demand.split("_")[-1]
print(year_tag)
demand_lyr = 'demand_lyr'
capacity_column = [x.name for x in arcpy.ListFields(scc_layer) if year_tag in x.name][0]
arcpy.AddMessage("begin optimization for {}...".format(demand))
arcpy.MakeFeatureLayer_management(demand, demand_lyr)
out_cluster = "cluster_" + demand
arcpy.AddJoin_management(demand_lyr, "OBJECTID", out_cluster, "SOURCE_ID")
cluster_expression = [x.name for x in arcpy.ListFields(demand_lyr) if "CLUSTER" in x.name][0] + " = -1"
arcpy.SelectLayerByAttribute_management(demand_lyr, "NEW_SELECTION", cluster_expression)
mean_centers = "meancenter_" + demand
mean_centers_lyr = mean_centers + "_lyr"
arcpy.MakeFeatureLayer_management(mean_centers, mean_centers_lyr, arcpy.AddFieldDelimiters(mean_centers, "CLUSTER_ID") + " >= 0") # clustered stores
loc_alloc = arcpy.nax.LocationAllocation(nd_layer)
loc_alloc.accumulateAttributeNames = ['miles']
loc_alloc.travelMode = travel_mode
loc_alloc.travelDirection = arcpy.nax.TravelDirection.FromFacility
loc_alloc.problemType = arcpy.nax.LocationAllocationProblemType.MaximizeCapacitatedCoverage
loc_alloc.facilityCount = site_count
loc_alloc.defaultImpedanceCutoff = search_cutoff
loc_alloc.lineShapeType = arcpy.nax.LineShapeType.StraightLine
loc_alloc.distanceUnits = arcpy.nax.DistanceUnits.Miles
loc_alloc.timeUnits = arcpy.nax.TimeUnits.Minutes
field_mappings_facilities = loc_alloc.fieldMappings(arcpy.nax.LocationAllocationInputDataType.Facilities)
field_mappings_facilities["Name"].mappedFieldName = "scc_number"
field_mappings_facilities["Capacity"].mappedFieldName = capacity_column
loc_alloc.load(arcpy.nax.LocationAllocationInputDataType.Facilities, scc_layer, field_mappings_facilities, append=False)
#load non clustered stores
field_mappings_demand = loc_alloc.fieldMappings(arcpy.nax.LocationAllocationInputDataType.DemandPoints, use_location_fields=True)
field_mappings_demand["Name"].mappedFieldName = demand + ".store_number"
field_mappings_demand["Weight"].mappedFieldName = demand + ".avg_weekly_net_weight_dough"
for field in ['SourceID', 'SourceOID', 'PosAlong', 'SideOfEdge', 'CurbApproach', 'TimeCutoff', 'DistanceCutoff', 'Bearing', 'BearingTol', 'NavLatency', 'Cutoff']:
field_mappings_demand[field].mappedFieldName = demand + ".{}".format(field)
loc_alloc.load(arcpy.nax.LocationAllocationInputDataType.DemandPoints, demand_lyr, field_mappings_demand, append=False)
#load clustered stores
loc_alloc.setLocateSettingsOverrides(arcpy.nax.LocationAllocationInputDataType.DemandPoints, allow_auto_relocate=True, search_tolerance=16000)
field_mappings_clusters = loc_alloc.fieldMappings(arcpy.nax.LocationAllocationInputDataType.DemandPoints, use_location_fields=True)
field_mappings_clusters["Name"].mappedFieldName = "CLUSTER_ID"
field_mappings_clusters["Weight"].mappedFieldName = "SUM_" + demand + "_avg_weekly_net_weight_dough"
field_mappings_clusters[field].mappedFieldName = demand + ".{}".format(field)
loc_alloc.load(arcpy.nax.LocationAllocationInputDataType.DemandPoints, mean_centers_lyr, field_mappings_clusters)
#load_line_barriers
loc_alloc.load(arcpy.nax.LocationAllocationInputDataType.LineBarriers, line_barriers)
result = loc_alloc.solve()
if result.solveSucceeded:
arcpy.AddMessage("{} complete".format(demand))
result.export(arcpy.nax.LocationAllocationOutputDataType.Lines, os.path.join(geodatabase, "line_results_{}".format(demand)))
line_fields = result.fieldNames(arcpy.nax.LocationAllocationOutputDataType.Lines)
line_data = [row for row in result.searchCursor(arcpy.nax.LocationAllocationOutputDataType.Lines, line_fields)]
lines_df = pd.DataFrame(line_data, columns=line_fields)
demand_df = pd.DataFrame.spatial.from_featureclass(demand)
clusters_df = pd.DataFrame.spatial.from_featureclass(out_cluster)
store_assignments_df = pd.merge(demand_df[['OBJECTID', 'store_number', 'avg_weekly_net_weight_dough', 'build_year']],
clusters_df[['SOURCE_ID', 'CLUSTER_ID']],
left_on='OBJECTID',
right_on='SOURCE_ID',
how='left')
store_assignments_df['DEMAND_ID'] = np.where(store_assignments_df['CLUSTER_ID'] == -1,
store_assignments_df['store_number'],
store_assignments_df['CLUSTER_ID']).astype(int)
lines_df[['ORIGIN', 'DESTINATION']] = lines_df["Name"].str.split(" - ", expand=True).astype(int)
store_assignments_df = pd.merge(store_assignments_df[['store_number', 'avg_weekly_net_weight_dough', 'build_year', 'DEMAND_ID']],
lines_df[['ORIGIN', 'DESTINATION']],
how='left',
left_on='DEMAND_ID',
right_on='DESTINATION')
#result_dict[demand]['lines'] = lines_df
print(result.solverMessages(arcpy.nax.MessageSeverity.All))
else:
arcpy.AddMessage("Solve failed")
arcpy.AddMessage(result.solverMessages(arcpy.nax.MessageSeverity.All))
store_assignments_df = pd.DataFrame(columns= ['store_number', 'avg_weekly_net_weight_dough', 'build_year', 'DEMAND_ID', 'ORIGIN', 'DESTINATION'])
#unchosen_facilities = []
arcpy.management.RemoveJoin(demand_lyr)
arcpy.Delete_management(demand_lyr)
arcpy.Delete_management(mean_centers_lyr)
del result, loc_alloc, field_mappings_facilities, field_mappings_demand, field_mappings_clusters
return store_assignments_df
def optimize_network(network_dataset, workspace, scc_locations, future_demand_list, line_barriers='line_barriers', search_cutoff_miles=800, site_count=20):
arcpy.env.workspace = workspace
nd_layer_name = "Routing_ND"
scc_lyr = 'scc_lyr'
line_lyr = "line_lyr"
# demand_lyr = 'demand_lyr'
arcpy.MakeFeatureLayer_management(scc_locations, scc_lyr)
arcpy.MakeFeatureLayer_management(line_barriers, line_lyr)
arcpy.nax.MakeNetworkDatasetLayer(network_dataset, nd_layer_name)
nd_travel_modes = arcpy.nax.GetTravelModes(nd_layer_name)
travel_mode = arcpy.nax.TravelMode(nd_travel_modes['Truck Distance'])
params = travel_mode.attributeParameters
params[('Driving a Truck', 'Restriction Usage')] = 5
travel_mode.attributeParameters = params
travel_mode.useHierarchy = True
#future_demand_list = arcpy.ListFeatureClasses("Stores*", feature_type='Point', feature_dataset="Store_Data")
arcpy.AddMessage("beginning model run for {} years...".format(len(future_demand_list)))
result_dict = {}
for demand in future_demand_list:
result_dict[demand] = location_allocation_tool(nd_layer=nd_layer_name,
travel_mode=travel_mode,
geodatabase=workspace,
demand=demand,
scc_layer=scc_lyr,
line_barriers=line_lyr,
search_cutoff=search_cutoff_miles,
site_count=site_count)
#result_dict[demand] = solve_result
arcpy.Delete_management(nd_layer_name)
arcpy.Delete_management(scc_lyr)
arcpy.Delete_management(line_lyr)
return result_dict
And here is a simplified version if that's too much (just an example of my workflow):
## simplified code that doesnt run, just shows a pared down workflow
scc_lyr = 'scc_lyr'
result_dict = {}
# loop through multiple years of demand
loc_alloc = arcpy.nax.LocationAllocation(nd_layer_name)
loc_alloc.facilityCount = 20
loc_alloc.defaultImpedanceCutoff = 800
field_mappings_facilities["Capacity"].mappedFieldName = "capacity_column"
#load_line_barriers
result_dict[demand] = demand_df
else:
