Road distance tool?
427
12-02-2023 11:51 AM
JessicaS
Hi everyone,
As a last-ditch effort, I'm looking for help with a problem I think I've researched to death. But hoping I've missed something you all know!
I have a simple problem: I need to calculate the distance between every point in one feature layer (vector points) and the nearest point in another feature layer (vector points), following the roads from a third feature layer (vector polyline). I know the Near tool is nearest euclidian straight-line distance, and I've seen suggestions using raster cost layers, which I could create, or this solution from a previous post: https://community.esri.com/t5/arcgis-network-analyst-questions/near-analysis-with-network-road-dista..., but it would be prohibitively time consuming for me to create points at each road intersection (there would be thousands).
It seems like point to point distance along a line would be easy to calculate. Am I missing something?
Thanks in advance for the help!
DavidPike
MVP Frequent Contributor
JaySandhu
You can use Network Analyst to accomplish your task. The road line feature class can be turned in to a network dataset. You do not need to create all intersections before building a network on it. You can use the Integrate tool to do that. Once you have a network dataset, you can use the Closest Facility solver to compute the path/distance from a set of incident locations to the one or more closest facility locations.
I suggest using the Network Analyst tutorials to help you with this.
Network Analyst tutorials—ArcGIS Pro | Documentation
Jay Sandhu
