We were all newbies at some point, so don't feel bad.
I'm assuming that you're doing a Vehicle Routing Problem, but please correct me if I'm wrong. If you are doing a VrP, then you can use the ServiceTime property on the Orders to do this. According to the documentation Vehicle routing problem analysis—Help | ArcGIS Desktop , ServiceTime "specifies how much time will be spent at the network location when the route visits it; that is, it stores the impedance value for the network location. A zero or null value indicates the network location requires no service time."
So if you want 10 minutes to be spent at each order, you can either set the default service time to 10 when loading the order locations or you can have a field called ServiceTime on the feature class that will be used for the orders and just fill in the value for each order.
Hope this helps, but let me know if I missed something
