Using ArcMap 10.5.1, using pre-assigned Orders in VRP I got the following 2 types of errors (after successfully solving several other pre-assigned Orders):
Warning: Routes (Name = "XXXX") has a pre-assigned Orders (Name = "XXXX") whose SpecialtyNames value is incompatible.
Warning: Routes (Name = "XXXX") has a pre-assignment that exceeds its MaxTotalTime value
Error: Constraint violations detected while loading pre-assigned orders, breaks and route renewals.
And then the solve failed without moving on to the rest of the (non-pre-assigned) Orders that I am certain are valid.
I know I can iteratively tweak these and run it again. But I would like to run the entire solution first and get a result of everything valid before I do that. Is there a way to tell VRP to ignore these errors and finish the solution, only telling me what failed afterwards?
Perhaps something similar to the Analysis Setting: "Ignore Invalid Order Locations", but for invalid Pre-Assigned Orders?
