If I have a map open in Arc Pro, but I also have a notebook open, the top ribbon that normally says "Project", "Map" etc when the map is activate changes to say "Project", "Notebook" etc when the notebook is active (e.g. is the last thing you clicked on) and it is extremely annoying becuase it is not obvious via a highlight around the notebook or map which is the active one
When the notebook is active you get the save etc options on the ribbon- please move these down to the notebook window, and then there is no need to change the ribbon at all.
If I'm bothering to use notebooks in Arc it is because I am moving between code and data on my map so I want the map options, such as explore and edit, available all the time.
