Error: TypeError: float() argument must be a string or a number, not 'dict'
2666
09-22-2023 12:01 PM
DonaldPike
I have a script that runs fine as a toolbox script in Desktop Pro, however when I try to run the same script in ArcGIS Online as a notebook, I get the following error:
For this line of code:
    new_feature_layer = sdf.spatial.to_featurelayer(
        title=f"Polys Centroids {tmp_uuid}",
        gis=gis,
        tags=["centroids", "outputs"],
        folder=TMP_FOLDER,
        sanitize_columns=False,
        service_name=f"polys_centroids_{tmp_uuid}",
Here's the full stack trace for the error:
TypeError                                 Traceback (most recent call last)
/tmp/ipykernel_59/1392681058.py in <cell line: 2396>()
   2422         param7
   2423     )
-> 2424     main(_args)
/tmp/ipykernel_59/1392681058.py in main(_args)
     64         print("PROCESSING FOR POLYS")
     65         _args.set_is_polys(True)
---> 66         run_steps(_args)
     67
     68
/tmp/ipykernel_59/1392681058.py in run_steps(_args)
     70     if not _args.is_test_mode:
     71         print("Starting download step")
---> 72         download(_args)
     73         print("Completed download step")
     74     print("Starting join step...")
/tmp/ipykernel_59/1392681058.py in download(_args)
    133     layer_item = gis.content.get(layer_id)
    134     if _args.is_polys:
--> 135         polys_feature_layer = generate_points(_args)
    136         output_file_centroids = polys_feature_layer.export(
    137             title="Polys_with_centroids",
/tmp/ipykernel_59/1392681058.py in generate_points(_args)
    113     )
    114     print(tmp_uuid)
--> 115     new_feature_layer = sdf.spatial.to_featurelayer(
    116         title=f"Polys Centroids {tmp_uuid}",
    117         gis=gis,
/opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_accessor.py in to_featurelayer(self, title, gis, tags, folder, sanitize_columns, service_name, **kwargs)
   2844                 )
   2845
-> 2846         result = content.import_data(
   2847             self._data,
   2848             folder=folder,
/opt/conda/lib/python3.9/site-packages/arcgis/gis/__init__.py in import_data(self, df, address_fields, folder, item_id, **kwargs)
   7562                 )
   7563
-> 7564                 ds = df.spatial.to_featureclass(
   7565                     location=os.path.join(temp_dir, name),
   7566                     sanitize_columns=sanitize_columns,
/opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_accessor.py in to_featureclass(self, location, overwrite, has_z, has_m, sanitize_columns)
   2635         origin_columns = self._data.columns.tolist()
   2636         origin_index = copy.deepcopy(self._data.index)
-> 2637         result = to_featureclass(
   2638             self,
   2639             location=location,
/opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_io/fileops.py in to_featureclass(geo, location, overwrite, validate, sanitize_columns, has_m, has_z)
   1106             return res
   1107         else:
-> 1108             res = _pyshp2(df=df, out_path=out_location, out_name=fc_name)
   1109             df.set_index(old_idx)
   1110             return res
/opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_io/fileops.py in _pyshp2(df, out_path, out_name)
   1334                 if value is np.nan:
   1335                     row[idx] = None
-> 1336             shpfile.record(*row)
   1337             del idx
   1338             del row
/opt/conda/lib/python3.9/site-packages/shapefile.py in record(self, *recordList, **recordDict)
   1835             # Blank fields for empty record
   1836             record = ["" for field in self.fields if field[0] != 'DeletionFlag']
-> 1837         self.__dbfRecord(record)
   1838
   1839     def __dbfRecord(self, record):
/opt/conda/lib/python3.9/site-packages/shapefile.py in __dbfRecord(self, record)
   1870                     value = format(value, "d")[:size].rjust(size) # caps the size if exceeds the field size
   1871                 else:
-> 1872                     value = float(value)
   1873                     value = format(value, ".%sf"%deci)[:size].rjust(size) # caps the size if exceeds the field size
   1874             elif fieldType == "D":
And this is the surrounding code in the method where the error occurs:
def generate_points(_args):
    gis = _args.gis
    poly_feature_layer = gis.content.get("7da90f1a777c4d6e9d59e3314e70fbe5")
    print(poly_feature_layer["url"])
    poly_feature_layer2 = FeatureLayer(poly_feature_layer["url"] + "/0")
    # EPSG 4326 is a coordinate system for lat/long that makes used of the WGS84
    # spheroid
    sr = 4326
    df = poly_feature_layer2.query(
        as_df=True, return_centroid=True, return_geometry=False, out_sr=sr
    print("Here 61")
    print(df.iloc[0])
    # Convert centroid to dict
    sdf = GeoAccessor.from_xy(
        df.join(pd.DataFrame(df.loc[:, "centroid"].to_dict()).T),
        "x",
        "y",
        sr=sr,
    print("Here 62")
    print(sdf.iloc[0])
    sdf = sdf.drop("Correct_Area_SqM", axis=1)
    print("Here 63")
    print(sdf.iloc[0])
    # Create a shortened uuid to avoid name clashes.
    # We made want to add cleanup for all temporary layers.
    tmp_uuid = "".join(
        random.choice(string.ascii_letters + string.digits) for _ in range(6)
    print(tmp_uuid)
        gis=gis,
        folder=TMP_FOLDER,
    return new_feature_layer
Tags (3)
DonaldPike
Update - I was able to get this issue (and some others that were also related) resolved by switching from the Standard to the Advanced runtime.
DanPatterson
Donald, you would be better off filing an issue with Tech Support, or better still, file one on the arcgis github site
Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python (github.com)
... sort of retired...
DonaldPike
Ok, thanks for the suggestion
DonaldPike
