Notebook Server cannot communicate outside the container
186
01-25-2024 02:33 AM
StefanUseldinger
Occasional Contributor II
We installed and configured NBS on a Ubuntu 22.04.3 LTS (GNU/Linux 5.15.0-91-generic x86_64) and try to communicate with our Portal.
First, we received the common error "Temporary failure in name resolution" which was fixed by adding the dockerExtraHosts
But after that, we received a timeout. We tried:
from arcgis.gis import GIS
gis = GIS(".../portal")
import requests
res = requests.get('https://...')
and received:
ConnectionError: HTTPSConnectionPool(host='...', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fece4dedd00>: Failed to establish a new connection: [Errno 110] Connection timed out'))
I saw that the docker containers being launched communicate via the bridge docker namespace/network. I connected myself to the container. Inside the container, curl requests failed, too. I checked iptables but did not see any blocking rules.
Do You have a clue how I can make NBS communicate with our Portal?
ArcGIS Notebook Server 11.2 Diagnostic Tool
Hostname: UBU-ARCGIS-NS
DIAG000: Check for installation as root [PASSED]
DIAG001: Check for 64-bit architecture [PASSED]
DIAG002: Check OS version [PASSED]
DIAG003: Check hostname for invalid characters [PASSED]
DIAG024: Check /etc/hosts for hostname entry [PASSED]
DIAG004: Check installed packages [PASSED]
DIAG028: Check for valid Docker install [PASSED]
DIAG005: Check system limits [PASSED]
DIAG009: Check HTTPS port [PASSED]
DIAG029: Check /var disk space [PASSED]
DIAG020: Check hostname IP address mismatches [PASSED]
DIAG026: Check ArcGIS Notebook Server core services [PASSED]
There were 0 failure(s) and 0 warning(s) found:
