Hi there, I'm fairly new to Notebooks and need some help debugging one that fails sporadically.
I've created a Notebook (in ArcGIS Online) that has four main steps:
- backs up a hosted feature layer view to a temporary FGDB
- appends the data from the temporary FGDB to a separate hosted feature layer
- updates the records added to the hosted feature layer to add a date/timestamp
- deletes the temporary FGDB
I've scheduled this Notebook to run every 15 minutes (which is the greatest frequency possible).
It's been running for a month (I initially set it off on June 14th), but sometimes fails to complete successfully. Twice in the last week it's failed to run on multiple successive runs and has been disabled automatically by ArcGIS Online. I've added try/except statements around all bits of code that are doing something, e.g. in the function to export an item to a temporary FGDB as shown below:
def backup_item_as_fgdb(itemid):
item = gis.content.get(itemid)
try:
result = item.export(item.title + "_backup_" + now_dt(), "File Geodatabase", tags= "VEL occupancy backup", snippet="Backup of {} taken on {}".format(item.title,dt.datetime.now().strftime("%c")))
print("VEL occupancy data successfully exported to FGDB.")
except:
print("An error occurred exporting the data to an FGDB: " + item.title)
try:
# move exported file to relevenat folder (in my ArcGIS Online account)
result.move(agol_backup_folder)
print("Temporary FGDB backup file successfully moved to folder: " + agol_backup_folder)
except:
print("An error occurred moving the FGDB backup to the specified folder: " + agol_backup_folder)
return result.id
But when it fails, I don't get any useful messages out of the task details view for the failed task, the errors block just says:
"errors": [
"[ERROR] - Terminating execute notebook job 32a37804e23d4deb834897fe28694e6a as scheduled notebook execution timeout 15 minutes exceeded."
Rather than printing the exceptions do I need to do something else with them? Do I need to return them?
I'd like to know at which of the four main steps it's failing so I can investigate further. Is anyone able to give any advice on how I can debug this better? Something somewhere is taking more than 15 minutes to run (which it shouldn't be) but it only happens sporadically and I really want to find out where the problem is so that I can be confident that this will run successfully all the time as it's our main backup/archive process for this project.
Any help would be greatly appreciated. Full task details of the failed task included below in case it's any help.
Thanks in advance - Ian
"result": {
"jobId": "32a37804e23d4deb834897fe28694e6a",
"type": "executeNotebook",
"status": "FAILED",
"username": **my username was here**",
"startTime": 1689190241118,
"endTime": 1689191226757,
"messages": [
"Input Notebook Path: /arcgis/home/.tasks/32a37804e23d4deb834897fe28694e6a/c13203e4fe554e8094d233ed5ed84db8.ipynb",
"Output Notebook Path: /arcgis/home/.tasks/32a37804e23d4deb834897fe28694e6a/output.ipynb",
"Start processing time: 2023-07-12 19:30:42.046459"
"errors": [
"inputs": {
"itemId": "c13203e4fe554e8094d233ed5ed84db8",
"updatePortalItem": true,
"saveInjectedParameters": false,
"notebookParameters": "{}",
"runId": "826766592cd04b60888579ca881d75ee",
"taskId": "39f24117f0e5434bbb0c0a925829b54f"
"results": {},
"customAttributes": {
"isCancelled": false
"jobError": null,
"jobType": null,
"serverId": null,
"notebookId": null,
"itemId": null,
"openNotebookProgress": null,
"notebookUrl": null
