Create a GIS map application that execute Python script on a selected area
444
10-06-2023 05:42 AM
Rakefet
Hi all,
I would like to create a map application with one widget that will allow the user to select an area on the map ( by drawing a rectangle) and another widget that will launch a dialog form where the extends of the rectangle will be populated in the dialog. Executing the dialog will display the results on the map.
I already created a custom arcGIS tool that does that but I want users that do not have an access to arcGIS to be able to use the tool.
is there any example that I can get some ideas how to do so?
thanks
BlakeTerhune
MVP Regular Contributor
I think you would first create a Python Toolbox or Script Tool with your script, then host it as a geoprocessing service. Once hosted, you can use it in your web app.
I see there is also a Web Tool in Portal that might be an option outside of a web app.
Rakefet
Thank you. I'll try to go this route. See how it will play out.
