I have a problem to display the calculated property value in javascript api label object. If anybody knows how to solve this issue, could you share your idea? Thanks!
Here is code:
| // create a renderer for the FNP layer to override default symbology |
var FNPColor = new Color("#666");
var FNPColor = new Color("#FF0000");
var FNPLine = new SimpleLineSymbol("solid", FNPColor, 1.5);
var FNPSymbol = new SimpleFillSymbol("solid", FNPLine, null);
var FNPRenderer = new SimpleRenderer(FNPSymbol);
mode: FeatureLayer.MODE_SELECTION,
outFields: ["*"],
| | | // create a text symbol to define the style of labels |
var FNPLabel = new TextSymbol().setColor(FNPColor);
FNPLabel.font.setSize("8pt");
FNPLabel.font.setFamily("arial");
var json = {
"labelExpressionInfo": [{ "value": "{Name}" },{"Value"}:calculateAcreageFNP}] // Here is the value need be displayed in the label
"labelPlacement": "above-right"
var labelClass = new LabelClass(json);
labelClass.symbol = FNPLabel; // symbol also can be set in LabelClass' json
FNPlayer.setLabelingInfo([labelClass]);
| | | function calculateAcreageFNP(value) { |
var sqft = geometryEngine.geodesicArea(value.geometry, "square-feet");
console.log(sqft);
var squarefeet = number.format(sqft, { places: 1 });
var acres = number.format(sqft / 43560, { places: 2 });
return "Acres :" + acres ;
