How to Remove Features from ArcGIS online using C#
3974
09-16-2014 04:37 AM
JessicaLott
New Contributor III
I use ArcGIS online and the ArcGIS Runtime for WPF products. I am able to add and edit features perfectly fine from code, however I can not delete them from code. I also can remove them from the Datagrid and manually through ArcGIS online.
The code I am currently is below:
private void RemoveQueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            FeatureLayer featurelayerSO = MyMap.Layers["ServiceOrders"] as FeatureLayer;
            FeatureSet featureSet = args.FeatureSet;
            try
                if (featureSet.Features.Count > 0)
                    featurelayerSO.Graphics.Remove(featureSet.Features[0]);
                    featurelayerSO.SaveEdits();
                    featurelayerSO.Update();
                else
                    MessageBox.Show("No features found");
            catch (Exception e)
                MessageBox.Show(e.Message);
When I step through this code, all of the values are showing as they should. The featureSet.Features[0] is exactly what I want it to be.. Any help would be appreciated. I am sure there is something simple I am missing.
Attached is a photo of the supported operations.
JessicaLott
New Contributor III
I was able to get this to work by using RemoveAt(ObjectID) instead of Remove(Graphic). I am going out on a limb and saying that it may be because the graphic in the featureset is not actually the graphic in the feature layer...?
MichaelBranscomb
Esri Frequent Contributor
I suggest taking a look at the Dev Summit examples: http://www.arcgis.com/home/item.html?id=3f69c79bbd7340b09fad396647a977a5
Specifically the Editing-Stand-Alone-Tables example.
Cheers
Mike
JessicaLott
New Contributor III
