Use older 8.2 VB 6.0 extension with ArcGIS 10.2
2604
02-24-2014 04:07 PM
LesSears
All,
I have an old extension was used with ArcGIS 8.2.  I believe it is a VB 6.0 extension that was written in 2004.  I do not have the original source code for the extension so I cannot recompile.
I ran the setup.exe of the original extension and also registered the dll using the ESRIRegASM utility - not sure if that was necessary or not.  The toolbar for the extension is available, but the extension is not listed in the extensions list.  When the toolbar comes up, at first of all the controls are enabled, but as soon as I click on the map, the extension toolbar's buttons and controls go to a disabled state.
So my question is, should this old extension work as-is with ArcGIS 10.2 and, if so, what do I need to do to get the toolbar functions enabled?
Thanks.
