Working from ArcGIS 10.2 sde environment I published a feature service with a domain to our ArcGIS Server. I then brought said service into ArcGIS Online and created a Geoform. The only problem is, when I when I went to populate the domain field in the geoform the values were out of order. When viewing the feature service in AGOL or Desktop the pick list is in the correct order. However, I have noticed that rest endpoint and geoform values are both in the same order but out of order when compared to Desktop and an AGOL map. There doesn't appear to be any specific logic to how the domain values are ordered when published, but somehow an AGOL map is able to know what the original order was set to be. Is there some way to get the geoform to display the correct order of values?
Example
domain in geodatabase | domain in rest endpoint |
A1 | B2 |
B2 | E5 |
C3 | D4 |
D4 | A1 |
E5 | C3 |
domain from published service in AGOL | domain pick list in geoform |
A1 | B2 |
B2 | E5 |
C3 | D4 |
D4 | A1 |
E5 | C3 |
