Deleting Fields from a Feature Service Via ArcGIS Pro
751
07-11-2017 03:35 PM
Perhaps this will be obvious to some, but hopefully it will help shorten the search I just went through:
Deleting any field that does not allow null values, while editing a feature service in ArcGIS Pro, will cause a breakage that will make it impossible to take that feature service offline in Collector. The following is an explanation of how I came to discover this fact.
I recently received the following message when trying to download a web map via Collector:
"Map download failed.  Unable to create replica. Please check your parameters. Internal replica error."
In addition to being unable to download the map in Collector, I also could not export the feature service as a file geodatabase.  After failing to find a solution to this myself, I searched the internet to no avail.  I finally had to create a new feature service using a local copy of the original geodatabase, then add all of the more recent data.
Though I was able to find a work around, I still wanted to understand what caused the issue in the first place.  After creating some test data, I was able to determine the deletion of any field that does not allow null values, while editing a feature service in ArcGIS Pro, will cause a breakage that will make it impossible to take that feature service offline in Collector and may cause problems when trying to export the feature service to a geodatabase.
Hopefully this will help others avoid this hang up in the future.
Version history
Last update:
‎07-11-2017 03:35 PM
Updated by:
Contributors
