Wiht the Map Viewer you can set a "Processing extent" (Environment settings) but not based on a Selection.
I need to run the Analysis only for the new records of my Feature layer. In ArcGIS Pro this is possible by selecting the new records.
I then would like to update the results to the existing Feature layer with the 50 drive time Polygon.
Here is a concrete example:
I have a feature layer that contains 50 locations (points). I have already calculated travel time polygons for these.
Now 30 new locations have been added for which I have to calculate the travel time polygons.
I have added these new locations to my existing feature layer.
Now I want my WebApp, which uses both feature layers (location points and travel time polygons), to be updated.
I don't want to create new feature layers whose symbolisation I have to adapt again and link to the apps. Some kind of select and update of an existing Feature layer with new Analysis results would be great.
