Add XY and length data to attribute table that automatically updates when features are changed on the map
2040
05-19-2015 11:26 AM
Status: Open
MiralemZeljo
New Contributor III
Could you please add a functionallity where attribute table updates lat long, length info for points/polylines.
Tags (1)
2 Comments
PeterSchneider
You can install the Attribute Assistant toolbar to update this information.  The toolbar requires two tables, a DynamicValue and a GenerateID table in SDE.  In there, you set what feature classes you want to automatically update upon creation of a new feature or update of an existing feature.  Second, the geometry length field should automatically update as it is a static field populated by ArcGIS.  If, it is a manually updated field, you should be able to set up the Attribute Assistant toolbar to populate this as well.  Finally, you wouldn't have any geometry for length in a point feature class.
http://resources.arcgis.com/en/help/localgovernment/10.2/index.html#//028s0000008n000000
Here is a screenshot of the tables in ArcSDE:
0EME0000000HRDZ
MegHoole1
I'd like to see this functionality in ArcGIS Online web maps - not just desktop
