Just as you can see the length as you draw a line, it would be helpful to see the radius of the circle you are drawing. We have users that need to draw circles around points to see if other features are within set distances. The clunky workaround is to draw a line with the proper radius length, then draw a circle using both ends of the line to define the center and radius. Then the line must be deleted. There should be an easier way!
