About datasets presentation
1503
04-26-2014 12:41 PM
GaëtanLAVENU
I wonder why the main title of the dataset is based on the feature service name. It would probably be more understandable to use the ArcGIS Online item title instead. As you can see on my attached screenshot, it will be more readable to inverse the current title and the sub-title of the dataset. ArcGIS Feature services names can't have spaces or special characters whereas item title is more explicit.
Regards,
Gaetan LAVENU
Esri France
by Anonymous User
Not applicable
Hi Gaetan,
Thanks for the feedback, we will consider this. Right now, when we have multiple datasets coming from one service, we wanted to note a lineage to the service. It may be possible that we remove the _ from the name, or as you mentioned consider the Item name.
Cheers,
Andrew
JustinConner
Occasional Contributor II
Just use the item name. Most of my services were created with names specific for their application. I don't want to rename the service so I have to create a new stand alone service.
