Hi all,
We have a wish to add a field to a hosted feature layer, but the option does not appear in an ArcGIS Online web map or the item's Data or Field pages for this item. When attempting to add the field in ArcGIS Pro, it also fails, with error 000852 given.
The hosted feature service was created from publishing a Survey123 form. In order to handle repeats, it contains a 'parent' feature layer, several 'repeat' feature layers and a 'repeat' table. There have been a number of views created from this feature service for web map and ops dashboard purposes, but it is a layer in the original hosted feature service that the additional field is required for, i.e. not a copy or view. Given all of these existing views and the established link to a Survey123 form, I would be reluctant to create and publish a new feature service.
Can anyone suggest what the problem might be?
As I say, it is not a copy and nor does it have related tile layers, both of which are listed here as being restrictions to adding or deleting a field. I came across this post with a similar problem, but our situation is not connected to the Election Management solution mentioned.
Thanks for any insight.
