I'm creating a story map series (in the style of http://storymaps.arcgis.com/en/app-list/map-series/). I need to add maps in each of the tabs. All of the tabs need to retrieve data from the same Map Server from the same REST endpoint (.../rest/services/Sustainability/Sustainability_Map/MapServer), but I need each tab to only show a different set of layers from that Map Server (see attachment to view what the REST endpoint looks like).
This is my ideal workflow:
1) Create a map for each tab
2) For each map, do "Add Layer from Web", and add the necessary layers by the index on the Map Server
e.g. For Energy, ".../rest/services/Sustainability/Sustainability_Map/MapServer/1"
e.g. For Climate Action, ".../rest/services/Sustainability/Sustainability_Map/MapServer/5"
e.g. For Built Environment, ".../rest/services/Sustainability/Sustainability_Map/MapServer/9"
Each of those indeces (1, 5, 9) have sub-layers (e.g. Under "Energy" (index 1), the sub-layers are Renewable Energy, Municipal Energy Efficiency, Community Energy Efficiency), and these would logically appear as the layers on each tab of my story map.
According to the answer on: https://community.esri.com/thread/36020, this should work! And I do remember being able to add specific layers by just adding the index at the end of the URL a year ago.
However, this is not happening for me now. I get the error "The layer is not a supported type and can not be added to the map." Can somebody please help me?
Thank you!
Derek
