Hi @RickeyFight,
For the editor, you'll need to change the feature templates. Support for managing feature templates within Map Viewer is on our future road map.
In the mean time, you can use either Map Viewer Classic or the Field Maps Designer app.
To manage feature templates in the Field Maps Designer app, follow these steps:
- Open the Field Maps Designer app.
- Navigate to the layer for which you want to manage feature templates.
- Tap on the 'Templates' tab, which contains the list of existing templates for that layer.
- To create a new template, tap on the 'Add Template' button and provide the necessary information.
- To edit an existing template, tap on the template you want to modify and make the desired changes.
- To delete a template, swipe left on the template and tap on the 'Delete' option.
Hope that helps!
