Greetings all.
I created a custom pop-up in MV Classic that includes values from 7 text attribute fields, plus up to 3 photos. 3 of the 7 fields are links to web pages, and I successfully configured the popup in Arcade to exclude rows with missing values for those 3 fields. (Sidebar: because the attributes with some missing values are links to web pages, I have not been able to figure out--despite exhaustive effort--how to collapse the resulting empty rows.) The popup worked well in MV classic and showed all of the text fields, with the photos at the bottom.
Here's the problem: I was requested to switch the order of the display such that it shows some text fields, then the media photos, and then the remaining text fields beneath that (for use in the feature information card in Web Experience Builder). When I re-order the popup info in new map viewer, the Arcade expression I used before loses functionality--all rows are displayed, even though they contain empty data, resulting in text that should be a link but doesn't have anything to link to, rather than a blank, empty line. The HTML that I try to copy over from old to new popup configuration fails. Below is a screen capture of the new popup and configuration in New MV, and following are my original Arcade expressions and the HTML in MV Classic that doesn't seem to translate in new MV.
What am I doing wrong?
Arcade expressions that worked in MV Classic (but returned a blank line if empty once formatted as links)
return IIF(IsEmpty($feature.Embeds), 'none', 'inline')
return IIF(IsEmpty($feature.Link1), 'none', 'inline')
The bottom attribute link is never empty, but the other two might be.
Thanks for any insights you can provide.
raena
rbd
