Arcade : Generate Random # Between X and Y
6624
03-08-2018 07:20 AM
BrianO_keefe
Arcade is excellent. I'm digging in and using it alot. But one of the things I am finding a need for is to generate random numbers. I build a lot of demo maps with fake data. I have to generate fake budgets, fake dates, etc. I generally just 'lorem ipsum' for descriptions but I need to be able to better generate more (close to) realistic numbers.
Does anyone know how I could do this with Arcade?
My preference would be Random(x) to get a number between 0 and X. But that isn't to be.
Anyone?
XanderBakker
Esri Esteemed Contributor
Since Random (Math Functions | ArcGIS for Developers ) returns a value between 0 and 1 you just multiply with the value you want to use as upper boundary:
Random() * X
If you want a value between A and B, you can do this:
Random() * (B - A) + A
XanderBakker
Random() * X
adam_gallaher
This works, but how can one get it to work by generating whole numbers? Currently, this is set up to produce floats or doubles.
Sarah_Saint-Ruth
You can use Round() and set it to 0 to return whole numbers i.e. Round(x,0)
anonymous55
Hello @Sarah_Saint-Ruth @XanderBakker
I need to create new field with unique ID for hosted layer which already published in AGOL. I can't find any Arcade code for creating unique ID for new field in AGOL . I am thinking about to copy object id to new field but I don't know the arcade code for it.
I will appreciate any help
